Bluefruit LE Sniffer 2269 does not show up in Wireshark
digitalsubtraction
Post by digitalsubtraction »
Setup per https://learn.adafruit.com/introducing- ... le-sniffer
  • Bluefruit LE Sniffer - Bluetooth Low Energy (BLE 4.0) - nRF51822 - Firmware Version 2 Product ID: 2269
  • Windows 11 Home 22H2 22621.755 64-bit operating system, x64-based processor
  • Silicon Labs CP210x USB to UART Bridge driver version 10.1.10.103
  • Python 3.11.0 with pyserial 3.5
  • Wireshark 4.0.1 (v4.0.1-0-ge9f3970b1527) with Npcap 1.71
  • nRF Sniffer for BLE package from Nordic Semiconductor installed via nrf_sniffer_for_bluetooth_le_4.1.1.zip
Notes:
Windows Device Manager > Ports (COM & LPT) appears as Silicon Labs CP210x USB to UART Bridge (COM4)
Python 3.11.0 (main, Oct 24 2022, 18:26:48) [MSC v.1933 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> print("hello")
hello
>>> import serial
Wireshark Help > About Wireshark > Folders shows separate Global Extcap and Personal Extcap paths rather than just one Extcap path as indicated in the tutorial.
All files indicated below put in BOTH Global Extcap and Personal Extcap paths:
Tried troubleshooting according to https://infocenter.nordicsemi.com/index ... intro.html especially "Make sure that the nRF Sniffer files can be run correctly" as follows:
C:\Program Files\Wireshark\extcap>nrf_sniffer_ble.bat --extcap-interfaces
extcap {version=4.1.1}{display=nRF Sniffer for Bluetooth LE}{help=https://www.nordicsemi.com/Software-and ... uetooth-LE}
control {number=0}{type=selector}{display=Device}{tooltip=Device list}
control {number=1}{type=selector}{display=Key}{tooltip=}
control {number=2}{type=string}{display=Value}{tooltip=6 digit passkey or 16 or 32 bytes encryption key in hexadecimal starting with '0x', big endian format.If the entered key is shorter than 16 or 32 bytes, it will be zero-padded in front'}{validation=\b^(([0-9]{6})|(0x[0-9a-fA-F]{1,64})|([0-9A-Fa-f]{2}[:-]){5}([0-9A-Fa-f]{2}) (public|random))$\b}
control {number=3}{type=string}{display=Adv Hop}{default=37,38,39}{tooltip=Advertising channel hop sequence. Change the order in which the sniffer switches advertising channels. Valid channels are 37, 38 and 39 separated by comma.}{validation=^\s*((37|38|39)\s*,\s*){0,2}(37|38|39){1}\s*$}{required=true}
control {number=7}{type=button}{display=Clear}{tooltop=Clear or remove device from Device list}
control {number=4}{type=button}{role=help}{display=Help}{tooltip=Access user guide (launches browser)}
control {number=5}{type=button}{role=restore}{display=Defaults}{tooltip=Resets the user interface and clears the log file}
control {number=6}{type=button}{role=logger}{display=Log}{tooltip=Log per interface}
value {control=0}{value= }{display=All advertising devices}{default=true}
value {control=0}{value=[00,00,00,00,00,00,0]}{display=Follow IRK}
value {control=1}{value=0}{display=Legacy Passkey}{default=true}
value {control=1}{value=1}{display=Legacy OOB data}
value {control=1}{value=2}{display=Legacy LTK}
value {control=1}{value=3}{display=SC LTK}
value {control=1}{value=4}{display=SC Private Key}
value {control=1}{value=5}{display=IRK}
value {control=1}{value=6}{display=Add LE address}
value {control=1}{value=7}{display=Follow LE address}
adafruit_support_carter
Re: Bluefruit LE Sniffer 2269 does not show up in Wireshark
The screencap of Wireshark is confusing. The sniffer is shown there. In your case, you are not seeing it?
digitalsubtraction
Sorry, this is all I see:
Can you double check the bag the board came in and make sure it's not one of these:
https://www.adafruit.com/product/2267
digitalsubtraction
P2269 W16647-E
adafruit2
Post by adafruit2 »
digital - when you plug into usb, not running any software, what do the LEDs on the board do?
digitalsubtraction
No LEDs illuminated at all.
digitalsubtraction
Please approve RMA.
kmakhilmchp
Post by kmakhilmchp »
Hi Team,
We recently purchased a Adafruit feather board based on nRF52840 module (Raytac): https://www.adafruit.com/product/4062
I followed the user guide to setup this board as BLE sniffer by using the mentioned firmware in user guide. But the hardware does not detect in Wireshark and not able to sniff the Bluetooth data. Please let me know how can you help on this?
User manual followed: https://cdn-learn.adafruit.com/download ... f52840.pdf
Product page: https://learn.adafruit.com/ble-sniffer-with-nrf52840
@kmakhilmchp Please start a new thread for your issue.
@digitalsubtraction Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement BLE Snifffer.
kmakhilmchp
adafruit_support_carter wrote: Mon Nov 14, 2022 12:30 pm @kmakhilmchp Please start a new thread for your issue.
Sure.
digitalsubtraction
Got my RMA replacement Bluefruit LE Sniffer 2269 today. Plugged it in and right away blue flashing LED & shows up in Wireshark. Solved. Thanks!
Return to “Wireless: WiFi and Bluetooth”
