I have tried several ways to use the Map Block to show the location of the data on my feeds, but I either get New York or some other place based on the value of the feed.
Try 1: Map Block of feed with both values and locations specified - in this example eCO2 sensor:
id value feed_id created_at lat lon ele
0F54XNRSVCS5YH0QW2DR978H25 449 2351782 2022-10-28 16:59:58 UTC 42.439732 71.095139 70
0F54XP2109JVQXSDV29240Y5NR 472 2351782 2022-10-28 17:00:28 UTC 42.439732 71.095139 70
0F54XPB8PGWXTFVEMCB00E1P1T 478 2351782 2022-10-28 17:00:59 UTC 42.439732 71.095139 70
0F54XPMFWK027SQMVMP48AES2D 478 2351782 2022-10-28 17:01:29 UTC 42.439732 71.095139 70
0F54XPXQD5G4P9JNFBQP7GXQV8 488 2351782 2022-10-28 17:01:59 UTC 42.439732 71.095139 70
0F54XQ6YJJ8NF8PFN9243H0GYW 489 2351782 2022-10-28 17:02:29 UTC 42.439732 71.095139 70
0F54XQG69ACB85S6AYVA7JB8MF 485 2351782 2022-10-28 17:03:00 UTC 42.439732 71.095139 70
Try 2: Map Block of feed that is the string of the location:
0F54XS7JPH5HDYMZ4WHDACRDRK 42.43973,71.09514,70.0 2353157 2022-10-28 17:06:01 UTC 0 0 0
0F54XSGSXADKGAPTV5S05RKPRH 42.43973,71.09514,70.0 2353157 2022-10-28 17:06:31 UTC 0 0 0
0F54XST1HBMEQT14BTR6JD5E8W 42.43973,71.09514,70.0 2353157 2022-10-28 17:07:02 UTC 0 0 0
0F54XT38NH3XY5ZJ3WWM7AFMHJ 42.43973,71.09514,70.0 2353157 2022-10-28 17:07:32 UTC 0 0 0
0F54XTCG5G0YY0YMNEXCN15C7R 42.43973,71.09514,70.0 2353157 2022-10-28 17:08:02 UTC 0 0 0
0F54XTNQCHYFWTQG13B7Q2S8WJ 42.43973,71.09514,70.0 2353157 2022-10-28 17:08:32 UTC 0 0 0
How do I format the data in the feed so that the Map Block shows the location based on Latitude and Longitude?
