I am having issues getting the LED glasses to work. I get the following error. Note that this is running the code from the is31fl3741_glassesrings.py example. I tried the projects from CircuitPython EyeLights Starter Projects and have the same issue so I started to try in individual examples to try debug.
code.py output:
File "code.py", line 9, in <module>
File "adafruit_is31fl3741/adafruit_ledglasses.py", line 256, in __init__
File "adafruit_is31fl3741/__init__.py", line 280, in __init__
File "adafruit_is31fl3741/__init__.py", line 105, in __init__
ValueError: No I2C device at address: 0x30
>>> import board
>>> import adafruit_is31fl3741
>>> from adafruit_is31fl3741.adafruit_ledglasses import LED_Glasses
>>> i2c = board.I2C()
>>> i2c.try_lock()
True
>>> i2c.scan()
[24]
>>> i2c.scan()
[24, 48]
>>> i2c.scan()
[24, 48]
>>> i2c.unlock()
>>> glasses = LED_Glasses(board.I2C(), allocate=adafruit_is31fl3741.MUST_BUFFER)
File "<stdin>", line 1, in <module>
Thanks for the Support!
