In the Adafruit SAMD 1.7.8 - 1.7.10 board libraries, the Trinket M0 doesn't work with the FastLED libraries.
Sample code is to try running the Blink example from FastLED on a Trinket M0. I used pin 3 as my data pin.
This works on Adafruit SAMD board libraries 1.7.7 and earlier.
On version 1.7.8, you get a verification error when trying to upload a sketch.
On versions 1.7.9 and 1.7.10, the LED doesn't blink or light up. Nothing worked with any FastLED sketch.
More detailed description of this bug at: https://github.com/FastLED/FastLED/issues/1363
From that description, you can work around the bug in the Adafruit SAMD library by uncommenting Line 12 in FastLED/src/fastled_config.h
// #define FASTLED_FORCE_SOFTWARE_PINS
Trinket M0 doesn't work with FastLED libraries
- billpugh
- mikeysklar
Re: Trinket M0 doesn't work with FastLED libraries
Thank you @billpugh.
This has come to our attention through the forums and Engineering is working to resolve it. As you pointed out there are work arounds. Here is another.
viewtopic.php?p=945599
