CircuitPython 8.0.0 Beta 4 Released!
danhalbert
Post by danhalbert »
From the GitHub release page:
This is CircuitPython 8.0.0-beta.4, a beta release for 8.0.0. It is relatively stable, but there will be further additions and fixes before final release.
WARNING: The flash partitioning for 2MB and 4MB flash ESP32 and ESP32-C3 boards has changed since 8.0.0-beta.2. When you load 8.0.0-beta.3 or later over beta.2 (or vice versa), on these boards, CIRCUITPY will be erased and reformatted.
WARNING: The flash partitioning for the Raspberry Pi Pico W has changed since 8.0.0-beta.1. When you load 8.0.0-beta.2 or later over beta.1 (or vice versa), on the Pico W, CIRCUITPY will be erased and reformatted.
Notable changes since 8.0.0-beta.3
  • ESP32-C3 builds now work again.
  • Raspberry Pi Pico W can act as a server, and can use static IP addresses.
Notable changes to 8.0.0 since 7.3.0
Functionality additions
  • Added WiFi workflow with browser-based device discovery, filesystem browsing, upload, download, file editing, serial/REPL connection (available only on Espressif for now).
  • Added a one-line status bar, which displays connection status, last exception, and version on a terminal window title or on the top line of an attached display. Support for status bar display is also being added to the Mu and Thonny editors.
  • .env file in CIRCUITPY specifies WiFI connection parameters, BLE name, and other startup values.
  • dotenv support: os.getenv() values are set by values in .env file. Values can be fetched from other dotenv-format files.
  • WiFi functionality implemented on the Raspberry Pi Pico W.
  • Revised Espressif camera support, now available on ESP32, ESP32-S2, and ESP32-S3.
  • Bulk analog input: analogbufio (available only on RP2040 for now).
  • Pin state can be preserved during deep sleep (available only on Espressif for now).
  • Allow setting USB VID, PID, manufacturer, and product ids at runtime.
  • Enabled collections.deque on most builds.
  • MP3Decoder and WaveFile can now take a filename instead of an open file.
  • AnalogIn values are full range from 0 to 65535, instead of having zeros on low-order bits.
  • In-place firmware update (dualbank) capability may be disabled in favor of a larger CIRCUITPY drive.
  • Added TileGrid.contains().
  • Added os.utime().
  • Added coproc module, for running programs on an on-chip co-processor. Currently available for the RISC-V core on the ESP32-S2 and ESP32-S3.
Compatibility changes
  • PulseOut no longer accepts a PWMOut. Use a Pin instead.
  • Auto-brightness support in displayio and framebufferio has been removed. It was never implemented completely.
  • OneWire is only in onewireio, and is no longer in busio or bitbangio.
  • gamepadshift has been removed: use keypad.ShiftRegisterKeys instead.
  • Print out whole-number floats exactly and correctly.
  • Restored rainbowio and onewireio to a number of boards. Some boards still have rainbowio turned off for space reasons.
  • i2ctarget.I2CTarget is the new name for i2cperipheral.I2CPeripheral. Accept both for now. I2CPeripheral will be removed in 9.0.0.
  • The property supervisor.runtime.ble_workflow replaces supervisor.disable_ble_workflow().
  • The property supervisor.runtime.next_stack_limit replaces supervisor.set_next_stack_limit().
  • The property supervisor.runtime.rgb_status_brightness replaces supervisor.set_rgb_status_brightness().
Download from circuitpython.org
Firmware downloads are available from the downloads page on circuitpython.org. The site makes it easy to select the correct file and language for your board.
Installation
To install follow the instructions in the Welcome to CircuitPython! guide. To install the latest libraries, see this page in that guide.
Try the latest version of the Mu editor for creating and editing your CircuitPython programs and for easy access to the CircuitPython serial connection (the REPL).
Documentation
Documentation is available in readthedocs.io.
Port status
CircuitPython has a number of "ports" that are the core implementations for different microcontroller families. Stability varies on a per-port basis. As of this release, these ports are consider stable:
  • atmel-samd: Microchip SAMD21, SAMx5x
  • cxd56: Sony Spresense
  • espressif: Espressif ESP32-S2
  • nrf: Nordic nRF52840, nRF52833
  • raspberrypi: Raspberry Pi RP2040
  • stm: ST STM32F4 chip family
These ports are considered alpha and will have bugs and missing functionality:
  • broadcom: Raspberry Pi boards such as RPi 4, RPi Zero 2W
  • espressif: ESP32, ESP32-S3, ESP32-C3
  • litex: fomu
  • mimxrt10xx: NXP i.MX RT10xxx
  • stm: ST non-STM32F4 chip families
Changes since 8.0.0-beta.3
Fixes and enhancements
  • Fix wake alarm saving. #7154. Thanks @dhalbert.
  • Fix _asyncio ticks. #7138. Thanks @jepler.
  • Fix missing _bleio.Characteristic.descriptors. #7130. Thanks @dhalbert.
  • Fix assigning attributes of GeneratorExit singleton. #7103. Thanks @jepler.
  • Enhance coproc module, including Coproc Alarm. #7102, #7091. Thanks @MicroDev1.
  • Fix usb_cdc.Serial.read() if not connected. #7100. Thanks @tannewt.
Port and board-specific changes
Broadcom
Espressif
  • Set correct architecture for ESP32-C3 builds and reorganize mpconfigport.mk. #7143, #7094. Thanks @MicroDev1.
  • Fix setup of Espressif PinAlarm. #7125. Thanks @dhalbert.
  • Fix error code for Socket.recv_into(). #7123. Thanks @georgboe.
i.MX
nRF
RP2040
  • Use correct pin count value. #7089. Thanks @jepler.
SAMx
STM
Individual boards
  • Espressif ESP32-S3-BOX: correct SPIRAM settings. #7140. Thanks @dhalbert.
  • LOLIN S3: fix and add pin definitions. #7145. Thanks @chukwon.
  • Raspberry Pi Pico W:
    • Implement sslsocket bind, listen, and accept. #7122. Thanks @jepler.
    • Enable and use SOF_REUSEADDR. #7119. Thanks @jepler.
    • Allow static IP settings. #7088. Thanks @jepler.
  • Raspberry Pi Pico and Pico W: add board.STEMMA_I2C() for use with Cowbell add-on boards. #7116. Thanks @kattni.
Documentation changes
  • Document port and board limitations for built-in modules. #7129, #7097. Thanks @dhalbert.
  • Remove MpyError. #7104. Thanks @jepler.
Build and infrastructure changes
Translation additions and improvements
  • Change phrasing of boot button message so it stands alone as a sentence, making translation easier. #7150. Thanks @Neradoc.
  • Thanks for translations:
    • @bergdahl (Swedish)
    • @Senuros (German)
    • @wtuemura (Portugese - Brazil)
New boards since 8.0.0-beta.2
  • Frood 42. Keebs. #7124. Thanks @piit79.
  • M5Stack ATOM Lite. #7142. Thanks @CDarius.
  • M5Stack Core Basic: #7144, #7133, #7120. Thanks @CDarius.
  • M5Stack Core Fire: #7113. Thanks @CDarius.
  • M5Stack Stamp C3: #7099. Thanks @CDarius.
Known issues Thanks
Thank you to all who used, tested, and contributed since 8.0.0-beta.3, including the contributors above, and many others on GitHub and Discord. Join us on the Discord chat to collaborate.
