Metro M4 Airlift Lite won't boot Arduino program
bgoolsby
Post by bgoolsby »
How can I make the Metro M4 boot into an Arduino program on power-up? I don't want to use CircuitPython. My programs work when I compile and download using the Arduino IDE, but when I simply plug in a 5V micro-USB power supply the program does not run.
mikeysklar
Re: Metro M4 Airlift Lite won't boot Arduino program
Post by mikeysklar »
Can you post a program you are running on the Arduino side? It might be waiting for a serial console. Several of the Adafruit examples use that.
bgoolsby
Post by bgoolsby »
Here is the code. It does wait for Serial to open - I will delete that part tonight and try it.
// 10/18/22 - Working.  Adafruit IO feed is "analog" and dashboard is "Analog in".
// 10/28 - Added BME280 to send humidity.  Using Adafruit library example bme280test.ino.
// 10/30 - Added separate temp and humidity feeds.  This works and feeds to Dashboard
//   Crawlspace.  Works when compiled and downloaded from Arduino, but does not work
//   when plugged into a 5V PS.
// Adafruit IO Analog In Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-analog-input
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/********************* Adafruit IO Configuration ****************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
Adafruit_BME280 bme; // I2C mode
// analog pin 0
#define PHOTOCELL_PIN A0
// feed states
float new_h = 0;
float last_h    = -1;
float new_t = 0;
float last_t    = -1;
// set up the feeds
AdafruitIO_Feed *feed_temp  = io.feed("cs_temp");
AdafruitIO_Feed *feed_humid = io.feed("cs_humid");
	pinMode(LED_BUILTIN, OUTPUT); //the LED marked "L"
	// start the serial connection
	Serial.begin(115200);
	// wait for serial monitor to open
	while(! Serial);
	// connect to io.adafruit.com
	Serial.print("Connecting to Adafruit IO");
	io.connect();
	// wait for a connection
	while(io.status() < AIO_CONNECTED) {
		Serial.println(io.statusText());
		digitalWrite(LED_BUILTIN, HIGH);	 // turn the LED on (HIGH is the voltage level)
		delay(250);											 // wait for a second
		digitalWrite(LED_BUILTIN, LOW);		// turn the LED off by making the voltage LOW
		delay(250);
	// we are connected
	Serial.println();
	// BME280 setup - default settings
	unsigned status = bme.begin();
	// You can also pass in a Wire library object like &Wire2
	// status = bme.begin(0x76, &Wire2)
	if (!status) {
		Serial.println("Could not find a valid BME280 sensor, check wiring, address, sensor ID!");
		Serial.print("SensorID was: 0x"); Serial.println(bme.sensorID(),16);
		Serial.print("		ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
		Serial.print("		ID of 0x56-0x58 represents a BMP 280,\n");
		Serial.print("		ID of 0x60 represents a BME 280.\n");
		Serial.print("		ID of 0x61 represents a BME 680.\n");
		while (1) delay(1000);
	// io.run(); is required for all sketches.
	// it should always be present at the top of your loop
	// function. it keeps the client connected to
	// io.adafruit.com, and processes any incoming data.
	io.run();
	float h = bme.readHumidity();
	h = float(int(h*2.0-0.5)) / 2.0; //round to 1/2 percent
	new_h = h;
	float t = bme.readTemperature();
	t = t*1.8 + 32; // to F
	t = float(int(t*2.0-0.5)) / 2.0; //round to 1/2 degree
	new_t = t;
	if(new_h != last_h) {
		// save the new_h state to the analog feed
		Serial.print("Sending H ->  ");
		Serial.print(new_h);
		Serial.println(" %");
		feed_humid->save(new_h);
	if(new_t != last_t) {
		// save the new_t state to the analog feed
		Serial.print("Sending T ->  ");
		Serial.print(new_t);
		Serial.println(" deg");
		feed_temp->save(new_t);
	// save last state
	last_h = new_h;
	last_t = new_t;
	// wait - free IO account limits updates to 30/minute
	// 2 feeds count as 2 separate updates
	delay(4000);
mikeysklar
	while(! Serial);
This is pretty common. As you suggest comment it out or run with the a serial console monitor open.
