I'm looking for a way to factory reset the "itsyBitsy nRF52840 Express", specifically the bluetooth side of things.
I'm writing a bit of code in Android and ever since it connected to my IB and tried to write to the RX characteristic, the rx_callback in my ino file doesn't fire (I have a .write() call in the rx to just echo the input) when connected to with any tool, including the Adafruit Bluefruit Connector.
When I swap out with a fresh IB board (always have a known good, right?) the ino script behaves as expected with the Adafruit Bluefruit Connector.
I'm assuming I did something boneheaded in my Android code, and so need to just flash the bluetooth side back to factory settings. I've found factory-reset for the other nrf boards, but I'm missing where the nrf52840 factory reset is. I also found a note about factory reset being removed for the nrf52840 from the adafruit github repo, but felt like that was probably done for a reason?
Thanks if anyone can shed any light on it for me.
Factory Reset - itsyBitsy nRF52840 Express
- mikeysklar
Re: Factory Reset - itsyBitsy nRF52840 Express
Does it need to be a real factory reset or would a fresh install of the bootloader and BLE code be adequate?
https://learn.adafruit.com/bluefruit-nr ... bootloader
From the Arduino IDE you could use:
Tools —> Bootloader
From the commandline:
Here is a link to the current bootloader (bottom right of page):
https://circuitpython.org/board/itsybit ... 0_express/
Tools —> Bootloader
$ adafruit-nrfutil --verbose dfu serial --package feather_nrf52832_bootloader-0.2.8_s132_6.1.1.zip
-p /dev/ttyACM0 -b 115200 --singlebank --touch 1200
