Motor Shield v2 with ESP32 - possible?
guibot
Post by guibot »
Hi, just like the topic says, I need to add connectivity to a project where there is an Arduino Uno and an Adafruit Motor Shield v2. I was thinking, instead of having an ESP32 sending commands to the arduino, to bypass the arduino, and have the ESP32 directly interfacing with the Motor Shield, is this possible? If possible, I might need some guidance as I'm a tinkerer, not an engineer, so please forgive me if this is a dumb question.
Thanks in advance
Re: Motor Shield v2 with ESP32 - possible?
Yes, that should be possible. You will need 4 wires to connect it. And you will need to configure the logic voltage jumper for 3.3v.
The logic voltage jumper is located near the 3v & 5v pins on the shield header. Cut the trace between the center pad and the 5v pad. Then solder a bridge between the center pad and the 3v. pad.
To connect to the ESP32:
  • GND->GND
    3v->3v
    SDA->SDA
    SCL->SCL
guibot
Post by guibot »
Thanks so much for the fast reply!
And the code should be exactly the same?
Yes. The code should be the same.
guibot
Post by guibot »
Thanks, I’ll give a try!
guibot
Post by guibot »
It just works, such a clever and well done shield from Adafruit!!
Thanks so much for helping!
