My Magtag device has successfully connected to the internet and executed the test requests adafruit supplied, but will not work with my code and returns a "duplicate header" error. Below is the complete code that I ran on my MagTag device as well as the error message that was returned.
import ssl
import wifi
import socketpool
import adafruit_requests
import json
# Get wifi details from a secrets.py file
from secrets import secrets
# Connect to wifi
wifi.radio.connect(secrets["ssid"],secrets["password"])
pool = socketpool.SocketPool(wifi.radio)
requests = adafruit_requests.Session(pool, ssl.create_default_context())
# Get json data
refreshToken = ''
client_id = ''
with open("TDtokens.json","r") as tokens_file, open("TDsecrets.json","r") as secrets_file:
refreshToken = json.load(tokens_file)['refresh_token']
client_id = json.load(secrets_file)['client_id']
# Refresh token needs to be triggered every 30 minutes, as authToken expires.
url = r"https://api.tdameritrade.com/v1/oauth2/token"
headers = {'Content-Type':'application/x-www-form-urlencoded'}
data = {'grant_type': 'refresh_token','refresh_token': refreshToken,'client_id':client_id}
authReply = requests.post(url=url, headers=headers, data=data)
print(authReply.json())
{'fault': {'faultstring': 'Duplicate Header "Content-Type"', 'detail': {'errorcode': 'protocol.http.DuplicateHeader'}}}
If you have any experience with Adafruit requests or Python requests any advice would be greatly appreciated.
