Have installed the hardware and followed the software instructions carefully to get this bonnet running on my Pi Zero. If I do "aplay xyz.wav" now, it plays off the bonnet speakers and all is well.
Also, when I go into alsamixer it shows "snd_rpi_hifiberry_dac" as the Card and shows one Playback called "PCM".
The only problem is that no matter how I adjust the level bar in alsamixer, it doesn't change the output volume. If I try "amixer set PCM 25%", same thing. No effect on the output.
I'm a little confused about what I'm doing wrong in the command line to control the output volume.
Thanks for your help!
Speaker Bonnet Volume Control?
- AlexMaghen
Re: Speaker Bonnet Volume Control?
Another piece of info: I noticed in the documentation something about it not handling Mono files. What's weird is that WAVs were Mono but it was playing them back fine. In any case, I thought maybe somehow the fact that they were Mono was keeping the volume control from working. So I made them Stereo. No effect. Volume adjustment still doesn't work.
Any help, much appreciated!
Alex
Alex
- AlexMaghen
Dear Adafruit people and community - I'm sorry to pester but this is driving me nuts. Anyone have any thoughts as to what I might be doing wrong here?
Alex
Alex
- adafruit_support_carter
When setting up the software, did you follow this step for enabling software volume control?
https://learn.adafruit.com/adafruit-spe ... ol-2711421
- AlexMaghen
Hi. Thanks for this! Question: I think I've done this already (though honestly, not sure - gotta check or redo it). But on the Adafruit site there's this warning:adafruit_support_carter wrote: ↑Thu Nov 17, 2022 3:12 pm When setting up the software, did you follow this step for enabling software volume control?
"2017-11-2 Raspbian PIXEL ('full') has broken something in volume control. I2S works, but there's no software volume setup, if you need this, try Raspbian Lite - will try to fix as soon as we figure out why :)"
I did "cat /etc/os-release" and got this...
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Alex
- jkotecki
I have installed the Raspberry Pi OS Lite 32bit on my Raspberry Pi Zero W Rev 1.1 with the speaker bonnet and followed the instructions. Playback works, but I am not able to adjust the volume. When I'm in the alsamixer, the up and down arrows don't do anything. I have been searching for a solution to no avail.
Not sure what's happening here. Just went through the install process:
https://learn.adafruit.com/adafruit-spe ... y-pi-usage
on a Pi Zero W starting with the 2022/09/22 Raspberry Pi Lite OS image.
After running the script and going through the reboots, a volume indicator shows up in alsamixer: Also, changing the level here did change the volume on the speakers. To test, would change the level in alsamixer, then exit, and run:
In my case, I did not need to do the additional steps in the "I2S Audio Tweaks" section of the guide. The install script seems to have taken care of everything.
speaker-test -l5 -c2 -t wav
- jkotecki
Interesting. I just installed Buster and changed the i2samp.sh script to say that it was supported, and now it's working as I expect. If I use the latest image and run the script, the alsamixer comes up but I am not able to adjust the volume.
- jkotecki
I just installed this image (https://downloads.raspberrypi.org/raspi ... ite.img.xz) and ran the i2samp.sh script to install, and the volume doesn't work. But doing the same steps with this image (https://downloads.raspberrypi.org/raspi ... f-lite.zip) does work. Obviously, they are different OS's and therefore different software versions. The version of alsamixer with Buster is 1.1.8 and Bullseye is 1.2.4.
