Can I use a Trinket MO and Adafruit 12-Channel 16-bit PWM LED Driver - SPI Interface - TLC59711 together. What pins to pins would I need to connect.
Thank you for all advice.
trinket MO and TLC59711
- dastels
Re: trinket MO and TLC59711
That should be fine. I suggest using hardware spi: MOSI (pin 4) for Di and SCK (pin 3) for CI and the hardware SPI constructor. See https://learn.adafruit.com/tlc5947-tlc5 ... ce-1476421. For more information, see the guide at https://learn.adafruit.com/tlc5947-tlc5 ... r-breakout.
- tobink64
I took your advice and tried using a TLC59711, and even tried running the programs from the overview pages. The trouble I ran into is now I am getting a memory allocation error.
File "code.py", line 3, in <module>
MemoryError: memory allocation failed, allocating 896 bytes
Thank You for any help you could provide
import board
import busio
import adafruit_tlc59711
print("tlc59711_simpletest.py")
spi = busio.SPI(board.SCK, MOSI=board.MOSI)
pixels = adafruit_tlc59711.TLC59711(spi, pixel_count=16)
pixels.set_pixel_all((10, 10, 10))
pixels[0] = (100, 100, 100)
pixels[1] = (0, 0, 100)
pixels[2] = (0.01, 0.0, 0.01)
pixels[3] = (0.1, 0.01, 0.0)
pixels.show()
- dastels
Hmmm... yeah. The TLC59711 module is pretty big. Unfortunately the M0 (SAMD21) doesn't have much RAM which really limits how much CircuitPython code you can load/run. It's fine for simple things, but anything more complex will run out of space quickly.
You have two real options:
1) switch to a board/MCU with more RAM. One of the QtPy boards (not the M0 one) would be good. Or something like an ItsyBitsy M4 Express or Feather M4 Express (or one with more RAM).
2) switch to programming in C++/Arduino.
- tobink64
Thank You for the response, I appreciate the help offered.
