Status of QOS
rdagger
Status of QOS
Post by rdagger »
I see several posts stating that only qos=0 is supported for publishing and only qos=0 & qos=1 are supported for subscribing. Is this still true?
When I subscribe to an Adafruit IO feed with qos=2 it does not throw an error. Also, when the onsubscribe method fires it returns a granted_qos parameter of 2.
jwcooper
Re: Status of QOS
Post by jwcooper »
IO supports qos 0 and 1, but not 2.
rdagger
Re: Status of QOS
Post by rdagger »
I suggest the granted_qos parameter should return the correct value or an unsupported error should be raised.
jwcooper
Re: Status of QOS
Post by jwcooper »
What MQTT client library are you using?
rdagger
Re: Status of QOS
Post by rdagger »
jwcooper wrote: Mon Nov 14, 2022 3:47 pm What MQTT client library are you using?
adafruit_minimqtt
