I am using the 16-Channel PWM / Servo Bonnet for Raspberry Pi, on a Pi zero 2 w. I attached a continuous servo and ran the Python example from the learn pages: https://learn.adafruit.com/adafruit-16- ... on-library
The motor will change speed and slow down, but never stop.
Any ideas?
import time
from adafruit_servokit import ServoKit
# Set channels to the number of servo channels on your kit.
# 8 for FeatherWing, 16 for Shield/HAT/Bonnet.
kit = ServoKit(channels=8)
kit.servo[0].angle = 180
kit.continuous_servo[1].throttle = 1
time.sleep(1)
kit.continuous_servo[1].throttle = -1
time.sleep(1)
kit.servo[0].angle = 0
kit.continuous_servo[1].throttle = 0
Continuous Server on 16-Channel Bonnet Doesn't Stop
- hiramk
- dastels
Re: Continuous Server on 16-Channel Bonnet Doesn't Stop
Continuous servos are problematic this way. They will stop if you turn off power to them. Most of them have a set screw that you can use to adjust the 0 position. Set its throttle to 0 and adjust the screw to stop the rotation.
- hiramk
HUGE THANKS! I will give this a try!!
- hiramk
That worked! Never would have figured that out. Once again, much appreciated!
- dastels
My pleasure.
