GFX Lib + Text Print - Refresh a Text Line?
awardblvr
Post by awardblvr »
Using the default font with Adafruit GFX library and ESP32-S2-TFT board, I need to refresh the last line of the display every so often with a new line of text.
I really don't want to disturb or re-write the other parts of the screen.
How can I blank just that bottom text line so I can refresh it with updated text?
I tried
tft.print("                    ")
but of course, all the previous pixels set by previous writes remain asserted.
Any suggestions?
atroph
Re: GFX Lib + Text Print - Refresh a Text Line?
Post by atroph »
I registered here for something very similar to this.
I'm using "TFT_eSPI.h" to do a simple clock demo and if I set the font color with:
tft.setTextColor(TFT_BLUE, TFT_BLACK);
(blue is font, black is background of the font) it writes and updates the TFT ok given that my background is also black.
However if I want to display just the font color without its associated background with
tft.setTextColor(TFT_BLUE);
every time the hour or minute changes it'll overwrite on top of the previous number and become a jumbled mess.
I'd much rather have the font be background independent and not have to have a matching background canvas of a solid color to rid of the surrounding blocks around the letters and numbers.
Wonder if there is something similar to a horizontal or vertical blank similar to analog TVs that I'm missing?
atroph
Post by atroph »
Few options I have read that may work.
1. Loop your routine for the area that you want to update twice.
Pseudocode:
updateTextArea(){
setTextColor(background)
move to x/y position
write old text that may or may not be still stored in left over variables
setTextColor(regularcolor)
load new values in variables
write new text
2. Use both arguments
with the given TFT library to set the text color AND the background color of the text.
3. Write full blocks in background color in the area that you want to update, then execute your normal write text routine.
[b]Encodings[/b]
HTML Entity (decimal)	█
HTML Entity (hex)	█
How to type in Microsoft Windows	Alt +2588 Alt 219
UTF-8 (hex)	0xE2 0x96 0x88 (e29688)
UTF-8 (binary)	11100010:10010110:10001000
UTF-16 (hex)	0x2588 (2588)
UTF-16 (decimal)	9,608
UTF-32 (hex)	0x00002588 (2588)
UTF-32 (decimal)	9,608
C/C++/Java source code	"\u2588"
Python source code	u"\u2588"
For now I'm just going to stick with a static background color and use the two argument set text color function (option 2). It works just fine.
atroph
Post by atroph »
Here is the code page for a full block. https://www.fileformat.info/info/unicod ... /index.htm
awardblvr
Post by awardblvr »
Thanks Everyone...
I created a solution for my needs... It assumes:
  • I own the full line,
  • I am only using default font, size 1,2,3
  • Only want colored text on black background.
void clearSizedTextLine(int8_t fontSize, int8_t pixelLine)
    int chars=0;
    switch (fontSize) {
        case 1:
            chars=41;
            break;
        case 2:
            chars=21;
            break;
        case 3:
            chars=14;
            break;
        default:
            return;
    tft.setTextSize(fontSize);
    tft.setCursor(0 /*x*/, pixelLine);
    tft.setTextColor(ST77XX_BLACK);
    while (--chars) {
        tft.print(char(0xDA)); // 0xDA is the CP437(false) square block
... which I call with something like:
#define DISP_BOTTOM_WARN_PIXEL 114
#define DISP_BOTTOM_WARN_SIZE 3
clearSizedTextLine(DISP_BOTTOM_WARN_SIZE, DISP_BOTTOM_WARN_PIXEL);
tft.setTextColor(ST77XX_RED);
tft.print("REBOOT in 4");
delay(4000);
ESP.restart();
Return to “Arduino”
