Jacob,
Considering that a RPi Pico W is $6.00, should the marginal one be mounted in acrylic and used as a paperweight?
I see that they are available at AdaFruit and MicroCenter.
Were the two RPi Pico W microcontrollers purchased at the same time, from the same vendor, look any different on the detail level? I know the old Pico has gone through at least two different 2MB flash memory chips. If your eyesight is like mine you will need a magnifying glass or jeweler's lope to see what is etched on the chips.
What is the available memory in the flash memory and the ram memory right after flash_nuke.uf2 and loading the same CircuitPython version. One of the boards may have partitioned off some memory it found defective or marginal. Refer to Paragraph #1
Bruce
MemoryError When Connecting Pico W with Azure IoT Central
- blakebr
- jbenowitz
Re: MemoryError When Connecting Pico W with Azure IoT Central
Hi Bruce,
My goal for this project to to monitor the local environments in my apartment in order to determine the best spot to place each of my house plants. Now that I can actually send & store the data, the project can begin :-)
Thanks again for all of your help. Unfortunately, at the moment I still am not 100% on what mistakes I was making... It may be that some of the libraries or CP itself was corrupted when unzipping/installing? Maybe one of the usb cables was not a proper data cable? Not sure exactly.
I did start using Notepad ++, liking it so far. Sometimes simple really is better.
- Jacob
You're absolutely right, once I commented that line back in - boom - data received and everything is functioning normal.Your output looks like stuff was sent. Line 76: #device.send_telemetry... is commented out in the screen dump shown. How do you determine that the information was received by Azure?
You had me laughing pretty good here! Don't ask me why, but I followed the same steps (fresh install of CP Beta4, fresh libraries, your code) on the marginal Pico, and it too is working now.Considering that a RPi Pico W is $6.00, should the marginal one be mounted in acrylic and used as a paperweight?
- Jacob
- azure_dashboard.jpg (71.57 KiB) Viewed 53 times
- pico_azure_connected.jpg (400.3 KiB) Viewed 53 times
- blakebr
Jacob,
I am glad both are working. It would have sucked if you had let the magic smoke out. We will probably never know what happened to make them work/not work. An invisible character, a misplaced space, tabs and spaces intermixed. Good luck optimizing your plants locations.
Bruce
Bruce
- jbenowitz
Haha, true that. Thanks again Bruce, wish you the best!
