trying to follow this example with a esp32-s3 tft board and this guide: (this guide says s2 but I have a s3 board if that matters ?)
https://learn.adafruit.com/adafruit-esp ... dafruit-io
i created the dashboard, put my IO creds and wifi info in the config file, the code compiled ok but when I open the serial monitor window it seems to be stuck here:
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
it just scrolls ..... across the screen. I cant really tell if that function also connects to wifi ? is there a way to enable a more verbose debug and see where it is getting stuck ?
thanks
adafruitio_26_led_btn example
- jimk123
Re: adafruitio_26_led_btn example
fyi before I started this I upgraded the adafruit IO arduino library to 4.2.3
- jimk123
my fault , had the wrong SSID/pwd
