does anyone know if mifi devices have enough bandwidth to run a esp32 device connected to IO using a toggle button ? I want to use a dasdboard with a toggle block to have the esp32 toggle relays and want to know if a mifi device (e.g. Version or ATT mifi) will work ? In some of the sample code I see in the loop section it calls io.run(); not sure if it is constantly connecting back (http ?) to IO for the status of a toggle block ?
thanks
bandwidth requirements IO ?
- brubell
- Learn User Page
Re: bandwidth requirements IO ?
It's hard to gauge this without seeing your code. IO.run() performs a MQTT PING request to the Adafruit IO broker, and a ping packet is generally ~56bytes.
- jimk123
Thanks for the quick reply, the code i am testing now is from the adafruit io library examples called adafruitio_26_led_btn example. Now sure how fast a loop is in arduino on a esp32-s3-tft so that could be a couple hundred calls per second ? Would adding a delay , say 100ms cause IO to timeout if high traffic becomes an issue ?
I am trying to find a replacement for a FONA board where 3g was discontinued, my app is in a remote location, i bought a att mifi device to replace the fona and was hoping to use IO with some toggle blocks on a dashboard to remote control relays via the esp32. Just trying to understand better if the data traffic will overwhelm the mifi device, or become cost prohibitive.
- brubell
- Learn User Page
Where would this delay be? Could you put attach some sample code so I can better understand.Would adding a delay , say 100ms cause IO to timeout if high traffic becomes an issue ?
- jimk123
not my code per say, I am using this code from the examples folder:
Arduino\libraries\Adafruit_IO_Arduino\examples\adafruitio_26_led_btn ( I think you are the author)
my q is in the loop it runs this: io.run(); and just wondering if that is going to cause of alot of data charges on my remote mifi device and if adding a delay before or after it would reduce the amount of traffic without causing the IO service to time out ? Another thought I had was run a test for a week on a dedicated mifi device and look the data charges on the vendors web site (tmobile). thoughts ?
thanks
thanks
// Adafruit IO Publish & Subscribe, Digital Input and Output Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Modified by Brent Rubell for Adafruit Industries
// Copyright (c) 2020 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// Button Pin
#define BUTTON_PIN 0
// LED Pin
#define LED_PIN LED_BUILTIN
// button state
bool btn_state = false;
bool prv_btn_state = false;
// set up the 'led' feed
AdafruitIO_Feed *led = io.feed("led");
// set up the 'button' feed
AdafruitIO_Feed *button = io.feed("button");
// set button pin as an input
pinMode(BUTTON_PIN, INPUT);
// set LED pin as an output
pinMode(LED_PIN, OUTPUT);
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
while(! Serial);
Serial.print("Connecting to Adafruit IO");
// connect to io.adafruit.com
io.connect();
// set up a message handler for the count feed.
// the handleMessage function (defined below)
// will be called whenever a message is
// received from adafruit io.
led->onMessage(handleMessage);
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
// we are connected
Serial.println();
Serial.println(io.statusText());
led->get();
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
// grab the btn_state state of the button.
if(digitalRead(BUTTON_PIN) == LOW)
btn_state = false;
else
btn_state = true;
// return if the btn state hasn't changed
if(btn_state == prv_btn_state)
return;
// save the btn_state state to the 'button' feed on adafruit io
Serial.print("sending button -> "); Serial.println(btn_state);
button->save(btn_state);
// store last button state
prv_btn_state = btn_state;
// this function is called whenever a 'led' message
// is received from Adafruit IO. it was attached to
// the counter feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
Serial.print("received <- ");
if(data->toPinLevel() == HIGH)
Serial.println("HIGH");
else
Serial.println("LOW");
digitalWrite(LED_PIN, data->toPinLevel());
- brubell
- Learn User Page
Performing a "soak test" is a good idea! You may want to create two different codes (one which has a delay built-in, the other which does not) and test both of them.Another thought I had was run a test for a week on a dedicated mifi device and look the data charges on the vendors web site (tmobile). thoughts ?
