Need Help With Code
- zivsi12
Need Help With Code
Hi im working on a code that toggle a light on and off with a light senser. my problem is whenever i press the button it works but i can turn off the func if you can help me it would be great thanks.
- blnkjns
Re: Need Help With Code
Please post code as code, not as image, that way we can put in suggestions.
Where does this code run on? Is it a part of more? Is it Visual Studio Platform IO?
Looks Arduinoish, but not completely.
I miss the main loop of the code. Also keep delays out of code whenever possible. It will give weird interaction.
Basically it has to be something like this (in pseudocode)
The idea behind 2 values is that it prevents stuttering on the desired turn-on light level. Also make sure the lamp does not cause a feedback loop: the light may not light the sensor.
boolean lampstate
int/float lightamount
upperlimit = somevalue
lowerlimit = somevalue
loop forever{
put sensorvalue in lightamount
if lightamount<lowerlimit set lampstate to on
if lightamount>upperlimit set lampstate to off
set light to lampstate
small delay (1) or do other things.
- zivsi12
By: Ziv Simoni
2022
#include "config.h"
#include <WiFi.h>
#include "WiFiClientSecure.h"
#include "AdafruitIO_WiFi.h"
#include <Wire.h>
#include <BH1750.h>
#define LED_BUILTIN 2
#define ssid "******" //******
#define pass "*******" //********
#define AIO_USERNAME "zivsi12" //personal info from adafruit.io
#define AIO_KEY "*********"
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 8883 // Using port 8883 for MQTTS
//sketch starts assuming the the light is off
boolean confirmRequestPending = true;
WiFiClientSecure client; // WiFi ClientSecure for SSL/TLS support
AdafruitIO_WiFi io(AIO_USERNAME, AIO_KEY, ssid, pass);
BH1750 lightMeter; //LightSensor
// io.adafruit.com root CA
const char* adafruitio_root_ca = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIDrzCCApegAwIBAgIQCDvgVpBCRrGhdWrJWZHHSjANBgkqhkiG9w0BAQUFADBh\n" \
"MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\n" \
"d3cuZGlnaWNlcnQuY29tMSAwHgYDVQQDExdEaWdpQ2VydCBHbG9iYWwgUm9vdCBD\n" \
"QTAeFw0wNjExMTAwMDAwMDBaFw0zMTExMTAwMDAwMDBaMGExCzAJBgNVBAYTAlVT\n" \
"MRUwEwYDVQQKEwxEaWdpQ2VydCBJbmMxGTAXBgNVBAsTEHd3dy5kaWdpY2VydC5j\n" \
"b20xIDAeBgNVBAMTF0RpZ2lDZXJ0IEdsb2JhbCBSb290IENBMIIBIjANBgkqhkiG\n" \
"9w0BAQEFAAOCAQ8AMIIBCgKCAQEA4jvhEXLeqKTTo1eqUKKPC3eQyaKl7hLOllsB\n" \
"CSDMAZOnTjC3U/dDxGkAV53ijSLdhwZAAIEJzs4bg7/fzTtxRuLWZscFs3YnFo97\n" \
"nh6Vfe63SKMI2tavegw5BmV/Sl0fvBf4q77uKNd0f3p4mVmFaG5cIzJLv07A6Fpt\n" \
"43C/dxC//AH2hdmoRBBYMql1GNXRor5H4idq9Joz+EkIYIvUX7Q6hL+hqkpMfT7P\n" \
"T19sdl6gSzeRntwi5m3OFBqOasv+zbMUZBfHWymeMr/y7vrTC0LUq7dBMtoM1O/4\n" \
"gdW7jVg/tRvoSSiicNoxBN33shbyTApOB6jtSj1etX+jkMOvJwIDAQABo2MwYTAO\n" \
"BgNVHQ8BAf8EBAMCAYYwDwYDVR0TAQH/BAUwAwEB/zAdBgNVHQ4EFgQUA95QNVbR\n" \
"TLtm8KPiGxvDl7I90VUwHwYDVR0jBBgwFoAUA95QNVbRTLtm8KPiGxvDl7I90VUw\n" \
"DQYJKoZIhvcNAQEFBQADggEBAMucN6pIExIK+t1EnE9SsPTfrgT1eXkIoyQY/Esr\n" \
"hMAtudXH/vTBH1jLuG2cenTnmCmrEbXjcKChzUyImZOMkXDiqw8cvpOp/2PV5Adg\n" \
"06O/nVsJ8dWO41P0jmP6P6fbtGbfYmbW0W5BjfIttep3Sp+dWOIrWcBAI+0tKIJF\n" \
"PnlUkiaY4IBIqDfv8NZ5YBberOgOzW6sRBc4L0na4UU+Krk2U886UAb3LujEV0ls\n" \
"YSEY1QSteDwsOoBrp+uvFRTp2InBuThs4pFsiv9kuXclVzDAGySj4dzp30d8tbQk\n" \
"CAUw7C29C79Fv1C5qfPrmAESrciIxpg0X40KPMbp1ZWVbd4=\n" \
"-----END CERTIFICATE-----\n";
AdafruitIO_Feed *led = io.feed("Led BuiltIn");
AdafruitIO_Feed *light = io.feed("Light Sensor");
AdafruitIO_Feed *toggleautol = io.feed("Toggle Auto Light");
int ledState = LOW; // the current state of LED
int lastTouchState; // the previous state of touch sensor
int currentTouchState; // the current state of touch sensor
delay(100);
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(115200);
WiFi.begin(ssid, pass);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
delay(250);
Serial.print("NOT CONNECTED");
delay(250);
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
Serial.println(WiFi.localIP());
client.setCACert(adafruitio_root_ca); // Set Adafruit IO's root CA
Serial.print("Connecting to Adafruit IO");
io.connect();
// set up a message handler for the 'color' feed.
// the handleMessage function (defined below) will be called whenever a message is received from adafruit io.
led->onMessage(handleMessage);
led->get();
Wire.begin(); //starts the lightsensor
lightMeter.begin();
toggleautol->onMessage(ToggleAutoLight);
toggleautol->get();
currentTouchState = touchRead(T0);
// Serial.println("loop starting"); //echo the message to terminal
if(WiFi.status() != WL_CONNECTED) {
delay(250);
io.connect();
delay(250);
io.run(); //is required by adafruit. it should always be present at the top of your loop function. it keeps the client connected to io.adafruit.com, and processes any incoming data.
delay(20);
ToggleTouch();
readlightSensor();
void readlightSensor() {
float lux = lightMeter.readLightLevel();
Serial.println("=========");
// reads the status of the light and sends to adafruit io
if(lux < 15) {
Serial.println("Light Off");
light->save(2);
else {
Serial.println("Light On");
light->save(1);
delay(3000);
void handleMessage(AdafruitIO_Data *data) {
Serial.print("Led Is -> ");
if(data->toPinLevel() == HIGH)
Serial.println("ON");
else
Serial.println("OFF");
digitalWrite(LED_BUILTIN, data->toPinLevel());
void ToggleAutoLight(AdafruitIO_Data *data) {
Serial.print("Auto Turn On is ->");
while(data->toPinLevel() == 1) {
AutoFunc();
if(data->toPinLevel() == 0) {
digitalWrite(LED_BUILTIN, LOW);
void AutoFunc() {
if(lux < 15) {
digitalWrite(LED_BUILTIN, HIGH);
Serial.println("===");
else {
Serial.println("***");
void ToggleTouch() {
lastTouchState = currentTouchState; // save the last state
currentTouchState = touchRead(T0); // read new state
if (lastTouchState > 35 && currentTouchState < 35) {
Serial.println("The sensor is touched");
// toggle state of LED
ledState = !ledState;
// control LED arccoding to the toggled state
digitalWrite(2, ledState);
