Hi Adafruit tech support,
I have a metro express M0 running circuitpython version 7.3.3
I installed adafruit-circuitpython-metro_m0_express-en_US-7.3.3.uf2
I updated the libraries using the lib bundle adafruit-circuitpython-bundle-7.x-mpy-20221107.zip
I am getting the following error
File "main.py", line 42, in <module>
AttributeError: 'module' object has no attribute 'Servo'
here's the code in main.py
# Servo on D5
servo = simpleio.Servo(board.D5)
Can some please provide some assistance with this issue
Thank you.
Ed Cantillo
Metro express M0
- mikeysklar
Re: Metro express M0
You want to use Adafruit_Motor now not simpleio.
You will need to copy over the library and import it in the code.py
This guide will help.
https://learn.adafruit.com/circuitpytho ... thon-servo
# SPDX-FileCopyrightText: 2018 Kattni Rembor for Adafruit Industries
"""CircuitPython Essentials Servo standard servo example"""
import time
import board
import pwmio
from adafruit_motor import servo
# create a PWMOut object on Pin A2.
pwm = pwmio.PWMOut(board.A2, duty_cycle=2 ** 15, frequency=50)
# Create a servo object, my_servo.
my_servo = servo.Servo(pwm)
while True:
for angle in range(0, 180, 5): # 0 - 180 degrees, 5 degrees at a time.
my_servo.angle = angle
time.sleep(0.05)
for angle in range(180, 0, -5): # 180 - 0 degrees, 5 degrees at a time.
time.sleep(0.05)
- EdCantillo
thank you for the reply much appreciated.
Actually I am trying to the main.py working. this was included after I installed the 7.3.3
it would be nice to have the sample code that came with the Adafruit Metro M0 express.
thank you
-Ed
thank you
-Ed
- mikeysklar
The sample code I provided above is what you would populate a main.py file with to control a stepper.
I’m not sure what the exact sample code that is currently shipping on the Metro M0 Express. My guess would be a basic blink example like this:
https://learn.adafruit.com/adafruit-met ... nk-2854174
// the setup function runs once when you press reset or power the board
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
