This is my current code
#include "config.h"
/************************ Example Starts Here *******************************/
// digital pin 2
#define LED_PIN 2
// set up the 'digital' feed
AdafruitIO_Feed *digital = io.feed("luzgaragem");
pinMode(LED_PIN, OUTPUT);
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
while(! Serial);
// connect to io.adafruit.com
Serial.print("Connecting to Adafruit IO");
io.connect();
// set up a message handler for the 'digital' feed.
// the handleMessage function (defined below)
// will be called whenever a message is
// received from adafruit io.
digital->onMessage(handleMessage);
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
// we are connected
Serial.println();
Serial.println(io.statusText());
digital->get();
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
// this function is called whenever an 'digital' feed message
// is received from Adafruit IO. it was attached to
// the 'digital' feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
Serial.print("received <- ");
if(data->toPinLevel() == HIGH)
Serial.println("HIGH");
else
Serial.println("LOW");
digitalWrite(LED_PIN, data->toPinLevel());
sorry for the simple question but i'm not used to english, it's not my mother language
