Servo/PWM Pi Hat Overheats
- t-o-m
I have a problem with the Servo/PWM hat from order 2953791-9009152585 on 11/4/22. The mosfet next to the barrel connector overheats almost immediately when I apply power to the board. I double-checked all of my soldering with a multimeter and there are no shorts introduced by the stacking header (photos attached), but I do read a short across +5 and GND, which I assume is across the mosfet. I have only powered it with the 5V 2A switching power supply from this purchase, and I confirmed that it puts out +5.15V on the center pin relative to ground on the outside of the barrel. Based on other people describing similar problems on message boards, it seems like the only solution is to replace the board.
- IMG_1493.jpg (160.48 KiB) Viewed 71 times
- IMG_1492.jpg (219.74 KiB) Viewed 71 times
- dastels
Re: Servo/PWM Pi Hat Overheats
Can you post clear closeups of the soldering on the headers. These photos don't show it clearly but it looks messy in places.
- t-o-m
It is messy, but I verified with a multimeter that there are no shorts between any of the pins on the header.
- t-o-m
This is the best I could do with the photo size limits. The problem is with the misfit, which doesn't have any connections to the header. For more context, the problem I'm having is the same as the one here:
viewtopic.php?f=8&t=73584
and here:
viewtopic.php?f=8&t=106367
If it helps, I can do what others have done and lift the mosfet's source and gate and apply power at the capacitor terminals.
and here:
- IMG_1512.jpg (210.79 KiB) Viewed 59 times
- dastels
The prognosis seems to be a bad FET resulting in a board replacement. Please email [email protected] with a link to this thread, your order number, and request the replacement of one 16-Channel PWM / Servo HAT for Raspberry Pi.
