Adafruit Heat Insert Press/Rig
Posted: Sat Nov 12, 2022 9:05 pm
Hello all,
For those that may have built the Adafruit heat insert press, there is an issue I commonly run into. The issue is when pressing heat inserts into non-through holes. Because the tip that comes with the soldering iron is a long slender cone, part of the tip always come through the bottom side of the heat insert. If you have material there (aka a non-through hole), the tip ends up burning into the part.
I am wondering if anyone has come across this issue, and if so what did you do? I am considering getting the Hakko T18-D24 tip as it is more of a screwdriver tip and may allow me to press from above as opposed to the tip going inside the insert.
Hope this makes sense
[/img]
