But both the Countdown Timer https://learn.adafruit.com/pyportal-eve ... down-clock and Hurricane Tracker https://learn.adafruit.com/pyportal-hurricane-tracker example apps don't exhibit that behavior.What does the status NeoPixel indicate once my code.py is
running?
Once your PyPortal boots up and successfully loads your code.py or
main.py, the status NeoPixel will turn green briefly. Then, the
NeoPixel will show one of the following color codes to indicate the
status of the WiFi connection/activity or file operations:
Red = not connected to WiFi
Blue = connected to WiFi
Yellow = fetching data
Blue = got data
Cyan = file opening
Countdown Timer goes to RED and stays there the entire time.
Hurricane Tracker goes RED, changes to YELLOW and stays there.
To test the status LED, I ran this code:
import time
import board
import neopixel
pixels=neopixel.NeoPixel(board.NEOPIXEL, 1)
pixels.fill((0, 0, 255))
whileTrue:
pass
Can anyone explain why those example apps don't work as expected?
TIA
