ESP32-S2 and test bed / I2C code
CuGat
Post by CuGat »
The example code at:
https://learn.adafruit.com/adafruit-qt- ... -scan-test
includes the following lines:
  Serial.begin(115200);
  // Wait for Serial port to open
  while (!Serial) {
    delay(10);
  delay(500);
  Serial.println("Adafruit I2C Scanner");
On a QT-PY ESP32-S2 connected by JST to a p/n 5640 clock generator, the code never exits the while loop for some reason(Arduino IDE 2.0.1) and nothing appears in the serial monitor window. Slowing the while loop does not work to fix the problem. Commenting out the while loop allows the code to execute normally and return the correct i2C address of the clock generator to the serial monitor. Why does the while loop fail?
adafruit_support_carter
Re: ESP32-S2 and test bed / I2C code
Not sure. Tested here and can not recreate that behavior. The loop is intended to wait until the Serial Monitor is opened before proceeding with the rest of the output.
Are you sure you're opening the correct COM port in the Serial Monitor? Double check the Tools->Port setting before opening it.
Return to “Other Arduino products from Adafruit”
