Adafruit ESP32-S2 TFT Feather Debugging
williamgill
Post by williamgill »
I have a Adafruit ESP32-S2 TFT Feather parsing some audio data and I'm writing in ardiunio ide (v 2). It will do a small number of samples, but with longer runs, the neo pixel flashes purple - which I think means there was an overflow somewhere. I've seen examples of errors / traces coming into the serial monitor, but I cannot seem to find how to get this data. How do I turn on any kind of debugging?
void testtwo() {
  unsigned long firstSampleTime = micros();
  unsigned long nextSampleTime = firstSampleTime;
  int samples = 0;
  int value;
  int normalizedValue;
  int buff[8];
  int readingAvg = 0;
  int Xcrossings[4] = {0,0,0,0}; //last three durations of half waves
  int prevNormalizedValue = 0;
  int crossingcounts = 0;  //a counter for moving through array of times the wave crosses the 0
  int theData[512];
  int bitCounter = 0;
  digitalWrite(LED_BUILTIN, HIGH);
while(bitCounter < 256) {
    //if its time to take a sample, do so
    if ((unsigned long)(micros() >= nextSampleTime)) {
      //read in audio via the ADC
      value = analogRead(AUDIO_IN_PIN);
      buff[samples % 8] = value; //put the raw reading in a rolling buffer - we are doing this so we can keep a rolling average
      //set the next sample time in the future
      nextSampleTime = firstSampleTime + samples * 125;
      //If there are 8 samples in the buffer, start doing work on the data
      if (samples > 7) {
        //get avg
        readingAvg = 0;
        for (int b = 0; b < 8; b++) {
          readingAvg += buff[b];
        readingAvg = readingAvg / 8;
        //the adc reads in all values as positive - to see the negative side of the audio waves, we've added ~1.5 volts to the input audio signal so the whole wave appears in the positive space.
        //We subtract the average read from each sample to normalize the data, half the wave below zero, half above
        normalizedValue = buff[samples % 8] - readingAvg;
        //if current sample and previous smaple are oposite signs, the wave has crossed the zero amplitude mark
        if((normalizedValue * prevNormalizedValue) <= 0){
          Xcrossings[crossingcounts % 4] = ( -normalizedValue / ((normalizedValue-prevNormalizedValue)/125) ) + samples*125;
          int one = Xcrossings[crossingcounts % 4] - Xcrossings[(crossingcounts-1) % 4];
          int two = Xcrossings[(crossingcounts-1) % 4] - Xcrossings[(crossingcounts-2) % 4];
          int three = Xcrossings[(crossingcounts-2) % 4] - Xcrossings[(crossingcounts-3) % 4];
          if(one < 333 and two < 333 and three < 333){
           theData[bitCounter] = 1;
           bitCounter = bitCounter + 1;
          if(one > 333 and two > 333){
           theData[bitCounter] = 0;
          crossingcounts++;
        prevNormalizedValue = normalizedValue; //for use next time through the loop to see if the wave has crossed 0
        //debugging output
        //values[samples-8] = normalizedValue;  // for visualizaiton of audio input
     //add to the count of samples taken
     samples++;
  Serial.println("Digital Output");
  for (int a = 0; a < 300; a++) {
    Serial.println(String(theData[a]));
  Serial.println("");
  Serial.println("");
  digitalWrite(LED_BUILTIN, LOW);
mikeysklar
Re: Adafruit ESP32-S2 TFT Feather Debugging
Post by mikeysklar »
Your code has some debugging output turned off. You might want to uncomment that.
Have you opened the Tools --> Serial Monitor in the Arduino IDE to see the output?
You can also enable verbose output during compilation / upload from File --> Preferences.
Return to “Arduino”
