Screw terminal breakout board
mikecreid
Post by mikecreid »
Can the audio fx boards mount into the feather screw terminal board?
The audio fx boards appear to be the same size as the feather boards
adafruit_support_mike
Re: Screw terminal breakout board
The space between the FX Board's pins is the same as the pin spacing on the Feather: 0.8" at 0.1" pitch, but the boards have different numbers of pins: the FX Board has 14 pins on each side. The Feather has 16 pins on one side and 12 pins on the other side.
