Watchdog timer not resetting esp32 board
crcibernetica
Post by crcibernetica »
Firmware: Adafruit CircuitPython 8.0.0-beta.4 on ESP32
WatchDogMode.RAISE does work correctly. There is an exception raised if I hold down the "kill switch" for more than 10 seconds. However, WatchDogMode.RESET does nothing that I can see.
import board
from digitalio import DigitalInOut
from microcontroller import watchdog as w
from watchdog import WatchDogMode
import time
# Kill switch -- normally high
button = DigitalInOut(board.IO4)
w.timeout = 10.0
w.mode = WatchDogMode.RAISE
while True:
    w.feed()
    while button.value == 0:
        pass
mikeysklar
Re: Watchdog timer not resetting esp32 board
Post by mikeysklar »
You have a simple reproducible chunk of code. Do you mind contributing to the existing issue that has been opened on the CircuitPython github repo?
https://github.com/adafruit/circuitpython/issues/5757
The above issue is M4 based on CP 7.x, but related to what you see that WatchDogMode.RESET is not working as expected.
crcibernetica
It doesn't appear to be the same issue. Before creating a new issue I wanted to understand if RESET simply hasn't been implemented on the ESP32 or if I am doing something wrong.
mikeysklar
There is a deinit fix that confirms ESP32 WatchDogMode.RESET is in place.
https://github.com/adafruit/circuitpython/pull/4325
https://github.com/adafruit/circuitpython/issues/4324
Creating a new issue makes sense in your case.
