This is arduino code:
#include "Adafruit_TinyUSB.h"
#define REPORT_SIZE 16
uint8_t const desc_hid_report[] = {TUD_HID_REPORT_DESC_GENERIC_INOUT(REPORT_SIZE)};
Adafruit_USBD_HID usb_hid(desc_hid_report, sizeof(desc_hid_report), HID_ITF_PROTOCOL_NONE, 1, true);
char char_buf[REPORT_SIZE];
void setup()
pinMode(D8, INPUT_PULLDOWN);
#if defined(ARDUINO_ARCH_MBED) && defined(ARDUINO_ARCH_RP2040)
TinyUSB_Device_Init(0);
#endif
usb_hid.enableOutEndpoint(true);
usb_hid.setPollInterval(1);
usb_hid.setReportDescriptor(desc_hid_report, sizeof(desc_hid_report));
usb_hid.setStringDescriptor("Spotify Keyboard");
usb_hid.setReportCallback(get_report, NULL);
usb_hid.begin();
Serial.begin(115200);
while( !TinyUSBDevice.mounted() ) delay(1);
Serial.println("Adafruit TinyUSB HID Generic In Out example");
int sense(void){
int volume =analogRead(A0);
return volume;
uint16_t get_report(uint8_t report_id, hid_report_type_t report_type,
uint8_t *buffer, uint16_t reqlen)
uint16_t size = snprintf(char_buf, REPORT_SIZE, "%d", sense());
for (int i = 0; i < size; i++)
buffer[i] = (uint8_t)char_buf[i];
return size;
void loop()
from re import S
import hid
import time
# default is TinyUSB (0xcafe), Adafruit (0x239a), RaspberryPi (0x2e8a), Espressif (0x303a) VID
USB_VID = (0xcafe, 0x239a, 0x2e8a, 0x303a)
print("VID list: " + ", ".join('%02x' % v for v in USB_VID))
for vid in USB_VID:
for dict in hid.enumerate(vid):
print(dict)
dev = hid.Device(dict['vendor_id'], dict['product_id'])
if dev:
while True:
# Get input from console and encode to UTF8 for array of chars.
# hid generic inout is single report therefore by HIDAPI requirement
# it must be preceeded with 0x00 as dummy reportID
# str_out = b'\x00'
# str_out += input("Send text to HID Device : ").encode('utf-8')
# dev.write(str_out)
str_in = dev.read(0,16)
print("Received from HID Device:", str_in, '\n')
time.sleep(1)
