Product 3984, PLATINUM RTD SENSOR - PT1000 - 3
I bought 2 PT1000 RTDs from digikey because the datasheet attached to the part lists the temp range with a max of 550C (see attached). But, when using them, i killed it pretty much around 350C. I then went to the adafruit website, and noticed that your site lists max temp as 280C.
I can confirm the limit is 280C!
You should update your digikey datasheet, as it is misleading.
thanks
Error in Datasheet for PT1000 RTD
Re: Error in Datasheet for PT1000 RTD
Yeah, that would be the difference between the RTD element and the cable assembly. At 280C there's a good chance you're melting any solder joints.
I'll let the folks who handle documentation know about the Digikey datasheet. Since this is a documentation error, let's also get you another cable.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement.
- jonvarteresian
thanks,
no need to worry about a replacement. i also noticed the digi-key search engine lists it at 550c (see attached). that should be updated at a min.
thanks
thanks
- pt10002.JPG (25.99 KiB) Viewed 60 times
We've gotten a new datasheet to Digikey, and will check the selection matrix as well.
