Nano Thermal Printer printing gibberish
pwnshop
Post by pwnshop »
I've researched this problem in this forum and nothing worked. I've also noticed that others with this problem have posted and have been advised to start a new thread. So here I am with my thread of the problem.
I recently purchased the Nano Thermal Printer. The test page prints out
"9600 baud". Noted. I've made this change where applicable. Where I'm running into problems is the How-To ( https://learn.adafruit.com/pi-thermal-printer ) seems to be out of date.
I start with a fresh copy of Raspbian from the RPi Imager. I upgrade and update til its as current as it gets.
Then, I install the packages and libraries needed as per the Pi Thermal Printer How-To instructions:
sudo apt-get install git cups wiringpi build-essential libcups2-dev libcupsimage2-dev python-serial python-pil python-unidecode
A number of these packages and libraries aren't found.
- wiringpi: not available
- python-serial: not available
- UTL package python-pil
- UTL package python-unicode
Git and cups does install.
Another observation: I've noticed these libraries do install in Buster (I think, can't confirm at the moment) after some experimentation.
I went another route and followed this YouTube video https://www.youtube.com/watch?v=LwKOvT7rCiU and was able to print from the command line using
echo -e "This is a test\\n\\n\\n" > /dev/serial0
with no problems. However, images and text files still print gibberish when printed from a print dialog.
I think the Adafruit tutorial on the Pi Thermal Printer needs a fresh set of eyes and update with current Pi models and Raspbian releases. In the mean time, what's a fix?
pburgess
Re: Nano Thermal Printer printing gibberish
Post by pburgess »
Have tested and confirmed that…
starting with: 2022-09-22-raspios-buster-armhf-lite.img.xz
and running:
sudo apt-get update
sudo apt-get upgrade
works.
Errors of this sort usually happen when a server hosting the corresponding package is unreachable. The usual recourse is to try again later, perhaps an hour or two, see if the network issue has cleared up.
