I've taken delivery of a Macropad and I'm trying to work through the examples but I'm failing. I've flashed CircuitPython 7.3.3 then I'm simply trying to get the example documented here: https://learn.adafruit.com/adafruit-mac ... pad-basics to work.
Unfortunately I'm getting an error:
code.py output:
File "code.py", line 11, in <module>
File "adafruit_macropad.py", line 251, in __init__
AttributeError: 'module' object has no attribute 'NEOPIXEL'
Code done running.
Adafruit CircuitPython 7.3.3 on 2022-08-29; Raspberry Pi Pico with rp2040
