DC Motor + Stepper Wing low current output
sebastienperth
Post by sebastienperth »
I have a DC Motor/stepper wing that is only putting out 0.05V from one of the 4 DC motor connections.
I was just testing out a motor I salvaged from a EZ/IO driver. It's a 12v DC geared motor.
It worked at first, and then about 10-15 seconds into working, it stopped.
I tested the other motor ports, and they are outputting the expected voltage based on the throttle setting.
Did I fry something?
Here's the very basic code I tested. The problem is only happening on M1.
import time
import board
from adafruit_motorkit import MotorKit
kit = MotorKit(i2c=board.I2C())
while True:
    kit.motor1.throttle = 1.0
    kit.motor2.throttle = 0.25
    kit.motor3.throttle = 0.5
    kit.motor4.throttle = 1.0
sebastienperth
Re: DC Motor + Stepper Wing low current output
I should have mentioned the wing is powered by a 12v source.
Do you have any electrical specs for the motor?
sebastienperth
I couldn't find the datasheet online.
The markings on it say:
DC geared motor
IG22C002045U62R
DC 12 V
No.18349058
SHAYANG YE Industrial Co. ltd
The manufacturer's website has mechanical specs - but nothing about the electrical specs:
http://www.shayangye.com/en/product-inner.aspx?f=s&i=39
If the motor pulls more than 1.2A for more than a few milliseconds, it is possible that it damaged the H-Bridge driver on the Wing.
If you have a multimeter, you can test the current draw of the motor when powered directly from your 12v source.
sebastienperth
I suspect that is what happened.
Shoot... but good to know.
Thank you!
