How do I save my MQTT Client user name and key as variables, instead to placing them as "#define" preprocessor. Has anyone done this? I have tried making the declaration as pointer but it keeps crashing.
Adafruit_MQTT_Client *mqtt = NULL;
mqtt = new Adafruit_MQTT_Client(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME1, AIO_KEY1);
This above method crashes when I publish, seems like I have to modulate the WiFiclient along with MQTT.
Is there a simpler solution for this? Would moving to rest api (io) solve this problem?
The motivation to store the keys as variables is so that I can encrypt them and save them in a private location.
I am using a Huzzah ESP8266 Board.
Has anyone got MQTT to work without using #define keys
- niyer
- brubell
- Learn User Page
Re: Has anyone got MQTT to work without using #define keys
you may want to take a look at this sketch for using a WiFiManager to dynamically set the parameters, https://github.com/adafruit/Adafruit_IO ... meters.ino
- niyer
Thank you, brubell. Yep I ended up going with "io".
