Trouble using QT Py RP2040 with Monochrome 0.91" 128x32 I2C OLED Display
- kcriqui
I've got a QT Py RP2040 connected to a Monochrome 0.91" 128x32 I2C OLED Display with a Qwiic cable and can't get anything other than a blank display. I'm coding with Arduino. The power LED on the display is lit. I can upload code to the board just fine and the I2C scanner sees the display at 0x3c. The example code SSD1306_128x32_i2c compiles and uploads fine but there is absolutely nothing on the display. I added a few Serial.println()'s after display updates and see those on the serial monitor, but not a thing on the display. Is there some incompatibility with these 2 boards?
- kcriqui
Re: Trouble using QT Py RP2040 with Monochrome 0.91" 128x32 I2C OLED Display
After much digging I found out that the I2C pins connected to the QWIIC connector are Wire1 rather than Wire used in the example code. The example is working now.
Is there a list somewhere of differences between the QT Py RP2040 and "normal" boards?
- adafruit_support_carter
There is no "normal" board. So just need to reference the pinout information specific to board being used.
https://learn.adafruit.com/adafruit-qt- ... qt-3091651
NOTE: To use this connector with CircuitPython, you need to use board.STEMMA_I2C(), or busio.I2C(board.SCL1, board.SDA1) in your code! In Arduino, it is Wire1.
