I’m new to RPi and recently purchased a PiTFT capacitive touch screen and cyberdeck hat, and have not been able to get the screen working. The PiTFT lights and stays illuminated completely white when the RPI is on.
Products:
- Raspberry Pi 400
- Adafruit PiTFT Plus 320x240 2.8” TFT + - - Capacitive Touch Screen [ID:2423]
Adafruit Cyberdeck Hat for Raspberry Pi 400 [ID: 4863]
Thanks in advance for your help!
Matt
PiTFT for RPi 400
Re: PiTFT for RPi 400
Have you gone through the installation process from the tutorial?
https://learn.adafruit.com/adafruit-2-8 ... -install-2
- mattsgoodman
Yes, I run the installer script and get the following results:
pi@raspberrypi:~ $ cd ~
pi@raspberrypi:~ $ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
pi@raspberrypi:~ $ sudo apt-get install -y git python3-pip
Building dependency tree
Reading state information... Done
git is already the newest version (1:2.20.1-2+deb10u4).
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 434 not upgraded.
pi@raspberrypi:~ $ sudo pip3 install --upgrade adafruit-python-shell click
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: adafruit-python-shell in /usr/local/lib/python3.7/dist-packages (1.6.0)
Requirement already up-to-date: click in /usr/local/lib/python3.7/dist-packages (8.1.3)
Requirement already satisfied, skipping upgrade: clint in /usr/local/lib/python3.7/dist-packages (from adafruit-python-shell) (0.5.1)
Requirement already satisfied, skipping upgrade: Adafruit-PlatformDetect in /usr/local/lib/python3.7/dist-packages (from adafruit-python-shell) (3.32.0)
Requirement already satisfied, skipping upgrade: importlib-metadata; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from click) (5.0.0)
Requirement already satisfied, skipping upgrade: args in /usr/local/lib/python3.7/dist-packages (from clint->adafruit-python-shell) (0.1.0)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.4; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->click) (4.4.0)
Requirement already satisfied, skipping upgrade: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->click) (3.10.0)
pi@raspberrypi:~ $ git clone https://github.com/adafruit/Raspberry-P ... cripts.git
fatal: destination path 'Raspberry-Pi-Installer-Scripts' already exists and is not an empty directory.
pi@raspberrypi:~ $ cd Raspberry-Pi-Installer-Scripts^C
pi@raspberrypi:~ $
Then when I try to mirror the HDMI output with the FBCP install commands, I get the following:
pi@raspberrypi:~ $ sudo python3 adafruit-pitft.py --display=28c --rotation=90 --install-type=fbcp
python3: can't open file 'adafruit-pitft.py': [Errno 2] No such file or directory
pi@raspberrypi:~ $
The ^C at the end of this line looks like something has gone wrong with the command:
Get to that point again and enter the following commands:mattsgoodman wrote: ↑Sun Nov 20, 2022 5:07 pm pi@raspberrypi:~ $ cd Raspberry-Pi-Installer-Scripts^C
/bin/pwd
ls
