I got a fresh version of this code from GitHub to make sure this isn't my fault. Here's the code:
# SPDX-FileCopyrightText: 2021 Brent Rubell, written for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import time
from adafruit_oauth2 import OAuth2
from adafruit_display_shapes.line import Line
from adafruit_pyportal import PyPortal
import rtc
# Calendar ID
CALENDAR_ID = "[email protected]"
# Maximum amount of events to display
MAX_EVENTS = 5
# Amount of time to wait between refreshing the calendar, in minutes
REFRESH_TIME = 15
MONTHS = {
1: "Jan",
2: "Feb",
3: "Mar",
4: "Apr",
5: "May",
6: "Jun",
7: "Jul",
8: "Aug",
9: "Sep",
10: "Oct",
11: "Nov",
12: "Dec",
# Dict. of day names for pretty-printing the header
WEEKDAYS = {
0: "Monday",
1: "Tuesday",
2: "Wednesday",
3: "Thursday",
4: "Friday",
5: "Saturday",
6: "Sunday",
# Add a secrets.py to your filesystem that has a dictionary called secrets with "ssid" and
# "password" keys with your WiFi credentials. DO NOT share that file or commit it into Git or other
# source control.
# pylint: disable=no-name-in-module,wrong-import-order
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
# Create the PyPortal object
pyportal = PyPortal()
r = rtc.RTC()
pyportal.network.connect()
# Initialize an OAuth2 object with GCal API scope
scopes = ["https://www.googleapis.com/auth/calendar.readonly"]
google_auth = OAuth2(
pyportal.network.requests,
secrets["google_client_id"],
secrets["google_client_secret"],
scopes,
secrets["google_access_token"],
secrets["google_refresh_token"],
def get_current_time(time_max=False):
"""Gets local time from Adafruit IO and converts to RFC3339 timestamp."""
# Get local time from Adafruit IO
pyportal.get_local_time(secrets["timezone"])
# Format as RFC339 timestamp
cur_time = r.datetime
if time_max: # maximum time to fetch events is midnight (4:59:59UTC)
cur_time_max = time.struct_time(
cur_time[0],
cur_time[1],
cur_time[2] + 1,
4,
59,
59,
cur_time[6],
cur_time[7],
cur_time[8],
cur_time = cur_time_max
cur_time = "{:04d}-{:02d}-{:02d}T{:02d}:{:02d}:{:02d}{:s}".format(
cur_time[0],
cur_time[1],
cur_time[2],
cur_time[3],
cur_time[4],
cur_time[5],
"Z",
return cur_time
def get_calendar_events(calendar_id, max_events, time_min):
"""Returns events on a specified calendar.
Response is a list of events ordered by their start date/time in ascending order.
time_max = get_current_time(time_max=True)
print("Fetching calendar events from {0} to {1}".format(time_min, time_max))
headers = {
"Authorization": "Bearer " + google_auth.access_token,
"Accept": "application/json",
"Content-Length": "0",
url = (
"https://www.googleapis.com/calendar/v3/calendars/{0}"
"/events?maxResults={1}&timeMin={2}&timeMax={3}&orderBy=startTime"
"&singleEvents=true".format(calendar_id, max_events, time_min, time_max)
resp = pyportal.network.requests.get(url, headers=headers)
resp_json = resp.json()
if "error" in resp_json:
raise RuntimeError("Error:", resp_json)
resp.close()
# parse the 'items' array so we can iterate over it easier
items = []
resp_items = resp_json["items"]
if not resp_items:
print("No events scheduled for today!")
for event in range(0, len(resp_items)):
items.append(resp_items[event])
return items
def format_datetime(datetime, pretty_date=False):
"""Formats ISO-formatted datetime returned by Google Calendar API into
a struct_time.
:param str datetime: Datetime string returned by Google Calendar API
:return: struct_time
times = datetime.split("T")
the_date = times[0]
the_time = times[1]
year, month, mday = [int(x) for x in the_date.split("-")]
the_time = the_time.split("-")[0]
if "Z" in the_time:
the_time = the_time.split("Z")[0]
hours, minutes, _ = [int(x) for x in the_time.split(":")]
am_pm = "am"
if hours >= 12:
am_pm = "pm"
# convert to 12hr time
hours -= 12
# via https://github.com/micropython/micropython/issues/3087
formatted_time = "{:01d}:{:02d}{:s}".format(hours, minutes, am_pm)
if pretty_date: # return a nice date for header label
formatted_date = "{} {}.{:02d}, {:04d} ".format(
WEEKDAYS[r.datetime[6]], MONTHS[month], mday, year
return formatted_date
# Event occurs today, return the time only
return formatted_time
def create_event_labels():
for event_idx in range(MAX_EVENTS):
event_start_label = pyportal.add_text(
text_font=font_events,
text_position=(7, 70 + (event_idx * 40)),
text_color=0x000000,
event_text_label = pyportal.add_text(
text_position=(88, 70 + (event_idx * 40)),
line_spacing=0.75,
event_labels.append((event_start_label, event_text_label))
def display_calendar_events(resp_events):
# Display all calendar events
for event_idx in range(len(resp_events)):
event = resp_events[event_idx]
# wrap event name around second line if necessary
event_name = PyPortal.wrap_nicely(event["summary"], 25)
event_name = "\n".join(event_name[0:2]) # only wrap 2 lines, truncate third..
event_start = event["start"]["dateTime"]
print("-" * 40)
print("Event Description: ", event_name)
print("Event Time:", format_datetime(event_start))
print("-" * 40)
pyportal.set_text(format_datetime(event_start), event_labels[event_idx][0])
pyportal.set_text(event_name, event_labels[event_idx][1])
# Clear any unused labels
for event_idx in range(len(resp_events), MAX_EVENTS):
pyportal.set_text("", event_labels[event_idx][0])
pyportal.set_text("", event_labels[event_idx][1])
pyportal.set_background(0xFFFFFF)
# Set up calendar event fonts
font_events = "fonts/Arial-14.pcf"
# Add the header
line_header = Line(0, 50, 320, 50, color=0x000000)
pyportal.splash.append(line_header)
label_header = pyportal.add_text(
text_font="fonts/Arial-18.pcf",
text_position=(10, 30),
event_labels = []
if not google_auth.refresh_access_token():
raise RuntimeError("Unable to refresh access token - has the token been revoked?")
access_token_obtained = int(time.monotonic())
events = []
while True:
# check if we need to refresh token
if (
int(time.monotonic()) - access_token_obtained
>= google_auth.access_token_expiration
print("Access token expired, refreshing...")
raise RuntimeError(
# fetch calendar events!
print("fetching local time...")
now = get_current_time()
# setup header label
pyportal.set_text(format_datetime(now, pretty_date=True), label_header)
print("fetching calendar events...")
events = get_calendar_events(CALENDAR_ID, MAX_EVENTS, now)
print("displaying events")
display_calendar_events(events)
print("Sleeping for %d minutes" % REFRESH_TIME)
time.sleep(REFRESH_TIME)
I ran it for a few hours tonight and it crashed on line 124 in get_calendar_events, which also calls adaferuit_requests.py, line 518, in _get_socket
File "code.py", line 244, in <module>
File "code.py", line 77, in get_current_time
File "adafruit_portalbase/__init__.py", line 488, in get_local_time
File "adafruit_portalbase/network.py", line 240, in get_local_time
File "adafruit_portalbase/network.py", line 209, in get_strftime
File "adafruit_requests.py", line 820, in get
File "adafruit_requests.py", line 666, in request
File "adafruit_requests.py", line 518, in _get_socket
RuntimeError: Sending request failed
