I'm just wondering if there's a datasheet for this product. On the Store, it says 3.6 ~ 12VDC. However, it's intended for automotive (motorcycle) implementation, so I would imagine it should be ok with the nominal running voltage of 13.5 ~ 14.5 VDC ???
Thanks for any help!
Silicone Button PWM Controller
- dastels
Re: Silicone Button PWM Controller
The description says:
So between 3.6v and 12v at 2A max. Those are the specs. Where do you read that it's intended for automotive/motorcycle use?These were originally designed for controlling heating pad modules in wearable thermal vests
