Hi, I have been playing around with the Adafruit stepper example CircuitPython code. I am using a Feather S3 board and a DC Motor + Stepper FeatherWing Add-on.
Is there any way to control the speed of the stepper? I am interested in running it smoothly and slowly. I have been using the time.sleep method but changing the sleep time does not have the effect I am looking for. I think I came across a really slow/smooth running sketch in Arduino/AccelStepper. Is there anything I can try in CircuitPython? Thanks!
Stepper question
Re: Stepper question
To make a stepper move slowly and smoothly, you need to microstep: controlling the coils so the rotor moves part of the way from one detente to the next.
The roughest version of microstepping is half-stepping: activating coil A, then adding coil be so both A and B are active, then shutting off A so only B is active. The rotor will move to the following positions:
A : at detente A
A+B : halfway between detente A and detente B
B : at detente B
Microstepping just activates the coils with less than 100% current. If coil A has 3x as much current as coil B, the rotor will stop 1/4 of the way from detente A to detente B. Then you can use equal currents to move the rotor halfway between detente A and detente B, then give coil B 3x as much current as coil A so the rotor stops 3/4 of the way from detente A to detente B.
The adafruit_motor module handles all that math for you. You just need to tell it how many positions you want between detentes:
https://docs.circuitpython.org/projects ... .MICROSTEP
Smooth slow motion involves lots of small microsteps at intervals short enough that you don't notice the rotor stopping at each position.
A : at detente A
B : at detente B
- forum_questions_1
Thanks for this good info Mike.
I was looking at the documentation and saw that it might be possible to change the default microsteps from 16 to 8 and also the 100 kHz frequency?
This is a beginner coding question. Where in code would I put "steppers_microsteps=8"? And how would I change the frequency? I'm just interested in how the motor changes with these.
Are these added in the parenthesis when I create the "kit"? Or somewhere else? I currently have kit defined as follows:
kit = MotorKit(i2c=board.I2C())
Yep, add the optional parameters when you create the Motorkit object:
(the default PWM frequency is 1.6kHz rather than 100kHz)
kit = MotorKit( i2c=board.I2C(), stepper_micrrosteps=4, pwm_frequency=1000 )
