I have several Cytron Maker Pi Pico boards with a Pico W installed. Their Demo Code fails when Pico W version of CircuitPython (CP) is installed, but runs when the Pico version of CP 8 Beta is installed. I believe this demonstrates a bug in the Pico W version of the CP 8 Beta, a bug which I am unable to correct. Both versions of their demo software should run identically. The W version fails.
I have attached a zip file containing the entire contents of the Circuitpy drive. Try it and you will see.
Thanks for your help.
CircuitPython 8 beta 4 Cytron Demo Code Fails
- Cyber175
- Cytron Maker Pi Pico Original Files.zip
- (195.83 KiB) Downloaded 2 times
- danhalbert
Re: CircuitPython 8 beta 4 Cytron Demo Code Fails
Please show us the backtrace and the detailed error. I would hazard a guess this is due to differences for `board.LED`, which is not a conventional pin on the Pico W. You might want to bring this up with Cytron, since this is their code, not ours.
- blakebr
I have a Pico W installed on a Maker Pi Pico and the WiFi works just fine. I actually have the Pico W WiFi and the ESP-01 WiFi working simultaneously. What I cannot do is use the SD Card I/O while in "W" Mode.Bruce
# WiFi & SD Card Stuff
Board = board.board_id
if Board == 'raspberry_pi_pico': Board = 'Pico'
elif Board == 'raspberry_pi_pico_w': Board = 'PicoW'
else:
print('No compatable OS or board found')
raise
AP_List_Flag = True
SD_card_Flag = True
ESP_01_WiFi = True
PicoW_WiFi = True
if (Board == 'PicoW'): SD_card_Flag = False
if (Board == 'Pico'): PicoW_WiFi = False
- jerryn
This may be relevant to the SDCard issue ...
https://github.com/CytronTechnologies/M ... O/issues/9
- blakebr
Jerry,
Thanks, I'll put that in my tool kit.
Bruce
Bruce
