I have RaspberryPi4, the Animated Snake Eyes Bonnet for Raspberry Pi, and 240x240 TFT (ST7789) displays. I am following the software installation instructions on learn.adafruit.com for the "Animated Snake Eyes Bonnet for Raspberry Pi"
When I run the install I get the following at the end of the install:
Installing Adafruit code and data in /boot...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
curl: (7) Failed to connect to github.com port 443: No route to host
unzip: cannot find or open master.zip, master.zip.zip or master.zip.ZIP.
cp: cannot stat 'Pi_Eyes-master': No such file or directory
Configuring system...
Done.
Then when I reboot, the backlights for the displays light but no graphics are displayed. Is my problem the following?
"curl: (7) Failed to connect to github.com port 443: No route to host
cp: cannot stat 'Pi_Eyes-master': No such file or directory"
I am wondering if there is possibly a missing file (master.zip) in the github installer script file:
"curl https://raw.githubusercontent.com/adafr ... pi-eyes.sh >pi-eyes.sh"
Any suggestions?
Thank you
Animated Snake Eyes Bonnet for Raspberry Pi - Missing file?
- TopekaSteve
- adafruit_support_carter
Re: Animated Snake Eyes Bonnet for Raspberry Pi - Missing file?
Based on this part of the output:
looks more like a network issue trying to connect to github.
Are you getting 443 errors everytime? If you just want to run the specific command that's failing, it's this:
curl -LO https://github.com/adafruit/Pi_Eyes/archive/master.zip
