Hi, my ESP32-S3-TFT board has arived and I am wondering where I can download the code that the board ships with when first powering up the board? The screen shows as follows
Adafuit Feather
ESP32-S3 TFT Demo
Battery 4.0V / 79% (I have a battery connected to the board)
I2C 0xB
Is the board running CircuitPython or Arduino and are the code examples for the ESP32-S2 compatible? The S2 code in the guide looks to be different and it would be good to save the S3 code before overwriting with my own code.
ESP32-S3 TFT initial configuration
- adafruit_support_carter
Re: ESP32-S3 TFT initial configuration
It's most likely an Arduino example. Not sure the source code is up anywhere. It's just a quick example put on for testing. You can reinstall it with the UF2 here:
https://learn.adafruit.com/adafruit-esp ... f2-3107942
Think I found it. Source is here:
https://github.com/adafruit/Adafruit_Le ... ryTest.ino
