I would like to plug a set of noods Flexible LED by serialize them (total = 4). Is it possible ?
Regards
nOOds Flexible LED
- dastels
Re: nOOds Flexible LED
From the guide (https://learn.adafruit.com/noods-uberguide):
DavenOOds can be connected in series (end-to-end) with a corresponding increase in voltage, e.g. 3V for one nOOd, 6V for two, 9V for three and so forth. You’ll still want a current-limiting resistor. Lower voltages might suffice, e.g. two red nOOds might work from a 5V supply…you’ll have to experiment. Probably best and easiest to work with these as parallel, not serial, components.
