I am having a issue with circuitpython and the mqqt lib. I am not sure where I am running into an issue.
Running a M4 express board with ethernet sheild, when I run the example - Connecting to the Adafruit IO MQTT Broker via (https://learn.adafruit.com/mqtt-in-circ ... qtt-broker)
I am not able to get a updated subscription and publish to a topic at the same time like the example shows. If I comment out the
#mqtt_client.loop()----> publishing occurs at the correct interval, but of course no subscription updates occur
mqtt_client.loop() active maintains the subscription but the program does not include any publishing commands below the mqqt_client.loop() entry.
Thank you for you Help!
Piotr
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import busio
from digitalio import DigitalInOut
from adafruit_wiznet5k.adafruit_wiznet5k import WIZNET5K
import adafruit_wiznet5k.adafruit_wiznet5k_socket as socket
import adafruit_minimqtt.adafruit_minimqtt as MQTT
# Get Adafruit IO details and more from a secrets.py file
try:
from secrets import secrets
except ImportError:
print("Adafruit IO secrets are kept in secrets.py, please add them there!")
raise
cs = DigitalInOut(board.D10)
spi_bus = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
# Initialize ethernet interface with DHCP
eth = WIZNET5K(spi_bus, cs)
### Feeds ###
# Setup a feed named 'photocell' for publishing to a feed
photocell_feed = secrets["aio_username"] + "/feeds/photocell"
# Setup a feed named 'onoff' for subscribing to changes
onoff_feed = secrets["aio_username"] + "/feeds/onoff"
### Code ###
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connected(client, userdata, flags, rc):
# This function will be called when the client is connected
# successfully to the broker.
print("Connected to Adafruit IO! Listening for topic changes on %s" % onoff_feed)
# Subscribe to all changes on the onoff_feed.
client.subscribe(onoff_feed)
def disconnected(client, userdata, rc):
# This method is called when the client is disconnected
print("Disconnected from Adafruit IO!")
def message(client, topic, message):
# This method is called when a topic the client is subscribed to
# has a new message.
print("New message on topic {0}: {1}".format(topic, message))
# Initialize MQTT interface with the ethernet interface
MQTT.set_socket(socket, eth)
# Set up a MiniMQTT Client
# NOTE: We'll need to connect insecurely for ethernet configurations.
mqtt_client = MQTT.MQTT(
broker="io.adafruit.com",
username=secrets["aio_username"],
password=secrets["aio_key"],
is_ssl=False,
# Setup the callback methods above
mqtt_client.on_connect = connected
mqtt_client.on_disconnect = disconnected
mqtt_client.on_message = message
# Connect the client to the MQTT broker.
print("Connecting to Adafruit IO...")
mqtt_client.connect()
photocell_val = 0
while True:
# Poll the message queue
mqtt_client.loop()
# Send a new message
print("Sending photocell value: %d..." % photocell_val)
mqtt_client.publish(photocell_feed, photocell_val)
print("Sent!")
photocell_val += 1
time.sleep(5)
