Power output vs draw mismatch - how close is close enough?
- urban_arrow
I want to add 2 Neon-Like LED Strips (Product ID: 3866) to my cargo bike via the accessory port on the Bosch motor which is a 12v, 1.5A output. Two of these strips (2 meters total) look like they draw 1.6A. What happens if the draw is .1A over the output? Does it matter? Will I explode?
Re: Power output vs draw mismatch - how close is close enough?
That depends on the power source.What happens if the draw is .1A over the output? Does it matter? Will I explode?
Some sources are conservatively rated and will produce stable voltage somewhat beyond the rated output. (whereas others may be optimistically rated and will struggle just to meet their specs). I'd expect a Bosch product to be well engineered and comfortably meet specs.
Once you exceed the actual maximum power output capacity of the source, several things could happen, depending on the design of the device:
- The voltage may start to drop as the current draw increases
- Fuses or internal protection circuitry may shut it down
- The device may overheat and fail
