Have a Adafruit 16 PWM Servo HAT connected to a Raspberry Pi 4B.
I get an error:
ValueError: No i2c device at address 0x40
When I try run:
import time
from adafruit_servokit import ServoKit
kit = ServoKit(channels=16)
kit.servo[0].angle = 180
kit.servo[4].angle = 20
time.sleep(0.5)
kit.servo[4].angle = 0
time.sleep(0.5)
kit.servo[0].angle = 0
Just as an fyi, i2cdetect -y 20 and i2cdetect -y 21 display contents, just not i2cdetect -y 1. Is that normal?
This exact same code runs perfectly when I connect the HAT to a raspberry pi zero.
-formlessform
- formlessform
- mikeysklar
Re: ValueError: No i2c device at address 0x40
I assume you have verified that i2c is enabled on the Pi 4B.
You could try moving the SD card with installed OS from the Pi Zero to the Pi 4B. That would help indicate if it is a OS setting.
