Adafruit HUZZAH32 - ESP32 Feather Measuring Battery
For Adafruit customers who seek help with microcontrollers
Draexler
Post by Draexler »
would like to measure the battery voltage. I am using an Adafruit HUZZAH32 - ESP32 Feather. According to the documentation, PIN A13 should be used. Since I do it later, I unfortunately can no longer get to this PIN structurally or for soldering. Can another PIN be used? Do I then have to double the value as well as described in the documentation?
I hope you can help me :-)
dastels
Re: Adafruit HUZZAH32 - ESP32 Feather Measuring Battery
Post by dastels »
A13 is not available as an external connection and is hardwared only to the voltage divider on Vbat. You just need to use it, exactly as stated in the tutorial: https://learn.adafruit.com/adafruit-huz ... ry-3122383 and in the FAQ
A13 / I35 - this pin is not exposed, it is used only for measuring the voltage on the battery. The voltage is divided by 2 so be sure to double it once you've done the analog reading
This approach to reading the battery is also used on the STM32f405 Feather, and it's guide includes the code needed:
#define VBATPIN A6
float measuredvbat = analogRead(VBATPIN);
measuredvbat *= 2;    // we divided by 2, so multiply back
measuredvbat *= 3.3;  // Multiply by 3.3V, our reference voltage
measuredvbat /= 1024; // convert to voltage
Serial.print("VBat: " ); Serial.println(measuredvbat);
You just need to change VBATPIN to be A13 instead of A6 (which is what is used on the STM board).
Draexler
Post by Draexler »
Very stupid question... Do I have to connect the A13 to a different PIN at all? I know that you normally have to supply voltage to the PIN so that a measurement can be carried out.
dastels
Post by dastels »
It's connected to a voltage divider internally (on the board); there isn't a place to connect to it. Hence "this pin is not exposed".
Return to “Microcontrollers”
