Hello, I had a powerboostshield in use in a project, it worked perfectly fine.
I don't use it stacked on, but next to my project.
I only soldered power and ground wiring.
But then one day I did some maintenance to the project and it seemed as though I blew up the powerboost...
When I plug in a charged battery the blue 5v led lights up for a millisecond, then the red battery comes in for a millisecond and after that all lights are off. When I plug usb the yellow charging led lights up. But there is no power at the 5v pin.
So I ordered 2 new shields...
I tested them before soldering, they worked fine, but as soon I plugged them to a Arduino the same thing happened.
So I have wiring from 5v shield to 5v on my mega and ground to ground.
First I had 5Vin to 5Vin that didn't work.
But honestly, I don't remember what the wiring was like, the last time it worked...
I assume I'm doing something completely wrong, but I can't find out what!
I saw the 500c might be more in place here, but I ordered again the stacking shield because the 500c was out of stock ...
Please help me out!
I think I blew up my powerboostshield...
Re: I think I blew up my powerboostshield...
Please post some photos showing all your soldering to the shields.
Also please post photos of the batteries you are using.
- Rosemarije
This is the latest shield, but can you just tell me, what should the wiring be like?
- rsz_incollage_20221123_140120364.jpg (184.18 KiB) Viewed 83 times
Assuming that the red wire is connected to 5v on the Arduino and the black wire to ground, that appears to be correct.
- Rosemarije
And if I had the 5v from the shield accidentally connected to the 5Vin on the board, would this blow up the shield?
What else could cause the behaviour I see now? (Blink blue 5v led, blink red low power and then nothing)
which 5v in on which board? Please post a photo or diagram of how you had things connected.And if I had the 5v from the shield accidentally connected to the 5Vin on the board, would this blow up the shield?
