This has to do with forum behavior so I hope someone can shed some light on this.
When I press Preview or Submit I get the following odd page view:
Opps! Now I cannot even upload the image (750x800)
What I see is a white sheet with my comments, not the normal forum page.
Just a moment ago I pressed Submit and got this strange white page, pressed the previous page button and was returned to my un-submitted page. I deleted the page and opened and new Adafruit forum page, went to the forum I was previously in and there was my thread. I have no idea what the problem is.
This issue is not new so I hope someone can shed some light on this.
Forum Behavior Question
- Franklin97355
Re: Forum Behavior Question
Once you select a file did you also click the place inline button under the others?
- _phillip
I will try to load the image again:
Nope. Same as before.
At the bottom where the file is listed all I see is the filename and a Delete File button.
That's it.
I will quit my browser and try again.
That's it.
- _phillip
Ah at least this time when I pressed the Submit button I did not get the white page.
- _phillip
will try uploading the image again.
same behavior as before: filename with Delete File blue button.
The file is 750x800 jpg.
I'm done with this.
Thanks.
I'm done with this.
Thanks.
- _phillip
I think I figured out the problem - at least this particuar problem. Here is the image of what I was seeing:
I think the reason I was not able to upload this image is because it contained a '?' at the end of its title.
Anyway, I see forum pages such as this time and time again.
- Franklin97355
So, do you have another question since you have solved the photo problem? Post a new topic if you do.
- _phillip
I'm good. Thank you.
