ESP32 with autoconnect has problems to send data to AdafruitIO
adafruit.io help, discussions and more!
paolometeo
Post by paolometeo »
my project consists in allowing an ESP32 board to connect to a WiFi network and to the AdafruitIO server, without writing the access credentials in the program. I wrote a program in Arduino C and it works for the auto-connection, but unfortunately I have encountered strange problems, which only appear after the board has transmitted data regularly 10 - 20 times to the server: the board undergoes an auto-reset for no apparent reason. The period between two data transmissions is 10 - 20 seconds.
Another program, without running autoconnect functions, works perfectly.
I suppose that it may be some conflict among the libraries; does anyone have experienced these problems?
In attached there is the zipped program.
Thank-you in advance
Paolo
Prova_regolatore_V2_test.rar
(3.97 KiB) Downloaded 8 times
Franklin97355
Re: ESP32 with autoconnect has problems to send data to AdafruitIO
Post by Franklin97355 »
Could you copy and paste your code between code tags( the </> button) so we can see it without having to extract the file?
Return to “Internet of Things: Adafruit IO”
