Help with adafruit FT232H with sparkfun 8-channel I2C mux
AnthonyOfGor
Post by AnthonyOfGor »
First off, I'm not a programmer.
I am trying to collect data from a bunch identical of I2C sensors that all have the same address. The hardware consists of my laptop connected to an Adafruit FT232H USB to I2C bridge followed by a sparkfun 8-channel I2C mux (TCA9548A).
I have successfully communicated to a BMP280 I2C sensor from my laptop to the BMP280 sensor through the FT232H just make sure I can make this work. But I'm having a lot of trouble communicating with the 8-channel mux.
I have installed the sparkfun-qwiic-i2c and sparkfun-qwiic-tcs9548a libraries on my laptop but I don't thing everything is there.
Has anyone done something similar to this before? Can you give me some code examples to follow?
Any help would be appreciated.
adafruit_support_carter
Re: Help with adafruit FT232H with sparkfun 8-channel I2C mux
Instead of the sparkfun libs, try this approach.
First, follow this guide for the main setup with the FT232H:
https://learn.adafruit.com/circuitpytho ... ith-ft232h
Then install the BMP280 CircuitPython library using pip:
https://github.com/adafruit/Adafruit_Ci ... hon_BMP280
as well as the TCA9548 CircuitPython library:
https://github.com/adafruit/Adafruit_Ci ... n_TCA9548A
Then checkout this guide for the general approach for using the TCA with multiple sensors:
https://learn.adafruit.com/working-with ... 2c-devices
